Browse Forums Interior Decorating Lounge 1 Aug 17, 2009 1:25 am Hi there We are up to the 'deciding on colours' stage and I need a bit of inspiration for the colours in our entranceway (and indeed the rest of the house). I know that I would like the walls a warm light brown colour that matches with my kitchen, and for the ceiling to be a warm off-white. The skirts, arcs and doors will most llikely be 1/2 or 1/4 strength of the wall colour. I quite like the Laminex clamshell colour but not sure if it might be too dark on the walls. Clamshell: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We have the following colours so far: Kitchen: Benchtop: Ceasar Stone, Ice Snow Lower Cabinets: Mocha (Formica Laminex) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Upper Cabinets: Angora (Formica Laminex) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Bathrooms: Benchtop: Laminex Pure Mineral Stone Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cabinets: Mocha (as above) Ceiling /Cornice - ?? Walls - ?? Skirting / Architrave - ?? Windows / Reveals / Frames - Windows: aluminium, Woodland Grey. All bedrooms to have painted reveals the same as archs and skirts, living areas we are considering leaving the wood finish. Doors - Similar to Corinthian Balmoral internal, front door is Corinthian Pivot Door (Madison) (to be painted Woodland Grey) Flooring - Hardwood floors, Grey Ironbark or something similar Carpet - light brown (sorry haven't chosen yet) Tiles or Vinyl - tiles: light brown (as above) Lighting - downlights in all living areas and through hallway entrance Anyway here is a picture of our hallway - along with suggestions for paints to match our kitchen, would love to hear about any suggestions regarding the colour for the entrance. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The room you see at the very end is the Theatre Room - I was thinking that perhaps a dark feature wall there might look good... what do you think? It currently looks yellow due to the soundboard. And there will be plaster on the roof just past the step up. Not sure how to deal with the cathedral ceiling where it becomes a triangular area. Any help would be greatly appreciated, thanks. kind Regards Mel The secret of success is enthusiasm .... http://romseyherewecome.blogspot.com/ Re: Colour help for entranceway please 3Aug 17, 2009 6:03 pm I would get a sample pot of the Calmshell, it could lean to the pink side? Just to be sure. It’s certainly NOT too dark for your walls. Getting a sample pot and painting it up will help you decide on that. But I think its fine. Ceilings/cornice - White Skirting/architrave – Clamshell full gloss or white Did you want to make a feature of the hall peak? (Cathedral ceiling) rake? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Colour help for entranceway please 4Aug 17, 2009 9:21 pm Thanks for your comments. D@n - good thought, but squaring it off isn't an option - we have a window at the front above the entry door which will provide light into the raked ceiling area and we specifically designed the house with this bit in mind. Thanks for the thought though! Michelle - good idea re the sample pot, will do that and see what the colour looks like. Any suggestions for other colours not quite as pink? Re the raked ceiling, we're not against making this a feature. There will be a fair amount of light coming in the top window above the entry door (in the mornings specifically) so we could make a feature of it. Would you suggest making it darker than the white? And what do you think about the Theatre room at the end of the hallway? Darker also .... perhaps the same colour as the raked ceiling, would that work? Thanks for your time and suggestions, much appreciated. Mel The secret of success is enthusiasm .... http://romseyherewecome.blogspot.com/ Re: Colour help for entranceway please 5Aug 18, 2009 6:56 am Actually I didn’t meant the ceiling to be a feature, I mean the entry wall that runs up to the raked ceiling….the wall we are looking at in the photo, sorry! Keep the ceilings all white. Since H/T rooms are mostly done dark, are you leaning this way also? I’ll wait till you answer some questions before I give you another flow colour. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Colour help for entranceway please 6Aug 18, 2009 10:07 am Hi Michelle, No problem, I wasn't quite sure of the question and hubby and I re-read it a couple of times and thought that was what you meant - sorry! Ceilings all white it is! Yes, I am leaning towards darker in the theatre rooms. Also the entrance to the room on the RHS is actually higher than shown, the plasterers hadn't finished cutting the top part of the plaster (if that makes any difference - probably doesn't I guess!). Thanks for your time! Mel The secret of success is enthusiasm .... http://romseyherewecome.blogspot.com/ Re: Colour help for entranceway please 7Aug 18, 2009 6:24 pm Yes…I get a cryptic sometimes…sorry about that! What colour were you thinking for your H/T room? Everyone is doing brown, what’s your thoughts? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Colour help for entranceway please 8Aug 19, 2009 9:48 am Hi Michelle Well yes I was thinking brown, however I'll be having brown kitchen, and a tinge of brown on the walls so perhaps also a brown theatre room might end up looking a bit stale and same old? I was thinking I'd use the same colour as for the rest of the house on the other walls, but with that wall as a feature wall, so it would need to be a colour that compliments with the standard colour I guess. At the end of the day the feature wall is only a wall of paint, so if we go a different colour and get sick of it in a couple of years then we can just repaint, can't we?? BTW, I was at a friends place who built with PD on the weekend, her walls were 'Scallopini' by Wattyl (I think it's Wattyl) and they were GORGEOUS... not sure if it suits the pallet of colours I already have going though? Thanks Mel The secret of success is enthusiasm .... http://romseyherewecome.blogspot.com/ Re: Colour help for entranceway please 9Aug 19, 2009 5:28 pm Mel, I’ll get back to this….its a biggy! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Colour help for entranceway please 10Aug 19, 2009 7:24 pm Hi Mel, your kitchen colours are very similar to ours If you want to have a squizz to see it in full size, click on my thread link in my siggie and you can see the kitchen on page 37. Blog: http://bluemistkids.blogspot.com "Never be afraid to try something new. Remember, amateurs built the ark, and professionals built the Titanic." Re: Colour help for entranceway please 11Aug 20, 2009 6:14 pm Ok let’s try these - Dulux Sandy Day ¼ as your main colour. This will look really good with your bench top. Sany Day 1/4 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Ceiling /Cornice – White Walls – Sany Day ¼ semi gloss Skirting / Architrave – White or Sandy Day ¼ - full gloss H/T room – Dulux Purple Prince – Flat. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And my Nicks Nooks….for the entry wall into the hallway. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Colour help for entranceway please 13Aug 20, 2009 11:07 pm Hi guys Hels - thanks for your offer to look at your piccies, your colour scheme is quite similar to ours and funnily enough your kitchen layout is very similar also (we have an L-shaped island bench in the same spot and cupoards directly behind). Your house looks beautiful, you must be very happy! Michelle - interesting, I really like the suggestions! The Nicks Nooks is similar to a colour I saw in a display home that I loved, but didn't quite know how it would work into the 'neutral' colour scheme.. i do like the idea of it being in the entrance way. And the purple.... I think I'm off to buy a couple of sample pots over the weekend to have a go and see how it looks! It will go beautifully with the nicks nooks in the front entranceway, as well as the main colour. Fantastic! Thanks so much for all your time and consideration. Kind Regards Mel The secret of success is enthusiasm .... http://romseyherewecome.blogspot.com/ Re: Colour help for entranceway please 14Aug 21, 2009 1:06 pm My pleasure, I hope it all goes well! Thanks buzz!!! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Thankyou so much 😀 I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK 😀 2 7142 Thank you @. Tried to play with the facade models but the exact colour is not matching up. 2 3230 Hi there, we have classic cream gutters, fascia’s, roller door and undercover carport. We are are going to paint the roof a terracotta orange colour. After some… 0 4490 |
