Browse Forums Interior Decorating Lounge 1 Aug 06, 2009 10:07 am We are having colorbond stone as our main house render colour, and i picked out colorbond riversand as the fence colour yesterday, and it turns out that riversand is actually stone.... Top and bottom fence rails will be estate, which is close to our roof colour jasper. Will this be too much of the same colour do you think? The front of the house will be a mixture of stone, with a the centre of the fascade being dune, as well as the roller door. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I am doing the top and bottom rails of the fence with estate, to get close to the roof colour we're having which is jasper, and the front of the house is going to be a mixture of the stone and dune. Thoughts? Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. Re: Too much of one colour? 4Aug 06, 2009 1:00 pm thanks, i think it should be okay, but thought i would ask picking colours is a bit scary Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. Re: Too much of one colour? 5Aug 06, 2009 5:03 pm I think it will look great! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8245 Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you… 3 5633 Not sure if that works? I was told the issue is the headspace clearance requirement on step 4. My builder is proposing shifting the beam 310mm towards the kitchen...I'm… 2 2490 |
