Browse Forums Interior Decorating Lounge 1 May 24, 2009 10:43 pm I have bought 50ml Eco blinds for most of my windows. I have read how to cut them to the correct width with a power saw. So I borrowed a power saw. It has the standard blade that comes with a drop saw. I am worried that blade will be too thick with too few teeth to cut down a blind and may split the blades of the blinds when I cut through the slab of blind slats. I went to Bunnings and saw that there were blades that were thinner and had a lot more teeth but they cost $60-100, the more teeth, the more expensive the blade. So will that blade be too thick to cut through the blinds cleanly even if I strap the blinds and masking tape where I cut through as per the instructions? The blade is 2mm thick but there are not a lot of teeth that is my concern. One part of me thinks it should be fine though provided the stack of slats is compressed tightly. I can clean up a roughish cut with a file (not that it would be that noticeable anyway) but if they split or crack I cant fix that. My alternative is to hacksaw my way through which I can do without splitting the blinds but when we are talking about a big blind that is quite a bit of hacksawing to cut through the slab of slats. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I am renovating a 3 bed house. I have no trades experience but I am keen to learn how renovate. I really appreciate the advice people give me here because I dont have a car so it is hard to get around trades places to talk to people. Re: Cutting down venetian Eco blinds - please help 3May 25, 2009 8:50 pm Get a professional to cut the blinds for you. I had some cut once…..I got a builder friend to do it, they turned out great! BUT…..yes you need to watch the splitting of the timber! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Cutting down venetian Eco blinds - please help 4May 25, 2009 9:41 pm I ommitted to say these are plastic blinds I am renovating a 3 bed house. I have no trades experience but I am keen to learn how renovate. I really appreciate the advice people give me here because I dont have a car so it is hard to get around trades places to talk to people. Re: Cutting down venetian Eco blinds - please help 5May 25, 2009 9:44 pm Good on ya! Cut them yourself...they should be fine. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Cutting down venetian Eco blinds - please help 6Jul 18, 2009 1:25 pm Hello, if I may help out here - you are better to use a minimum 60 tooth Carbide blade for Timbers and a minimum 80 tooth for Eco-blinds, PVC, and Plastics and Roller / Holland Blinds - anything less with result in damaged slats on your blinds and Slimline Alumunium bars use the 80 tooth also. - I am able to offer this help, I am in the business of blinds you see. Re: Cutting down venetian Eco blinds - please help 7Jul 20, 2009 8:46 pm Being Eco blinds they are made from PVC. The heat of the saw blade will melt the slats as you are cutting them. About a year ago, I embarked on a DIY project to construct an outdoor Pergola, which measures approximately 5.2 meters by 4.0… 0 29619 I have motorised roller blinds in my house. I motorised all the blinds I use a lot and the ones that don’t get used too often I didn’t. I went through Motorise My… 2 5972 How long is a "long period"? For a few weeks, it should be ok. It also depends on the area you live in...I would let your neighbours know that you will be away too and… 1 28576 |
