Browse Forums Interior Decorating Lounge 1 May 09, 2009 11:09 am Hello Seriously considering wallpaper-ing my bed head wall in the new place. But I am so confused about drops, pattern repeats etc., Now, the wallpaper I ADORE is 10metres x 52cm. Design Repeat 64cm with a Half Drop Match. WT? I get the 10 metres x 52cm. But the rest needs explaining please Our bedhead wall is 4.2metres x 2.7metres ceiling height. Online estimators say with 20% wastage I'd need 4 rolls, is that about right?? Thanks for your time! Meghan Building a Modified Lawson Modern 29 @ Botanic Ridge, Cranbourne South, Victoria Re: Wallpaper Help Please :) 2May 09, 2009 11:14 am Design Repeat 64cm with a Half Drop Match. This means….the pattern is repeated every 64cm, and you have a drop match to match the pattern up as you go where you need it. Take your dimensions to the wallpaper shop, they will work it out for you. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com All 3 items listed are defects and are of concern. Please seek qualified independent inspector and/or legal advice for your state. 1 9803 Thank you @. Tried to play with the facade models but the exact colour is not matching up. 2 5631 The requirement is for a waterstop to be installed to the entries of the room, (a small aluminum 'L' angle to retain the water to within the room) can't see if they have… 1 3953 |
