Browse Forums Interior Decorating Lounge Re: External rendering to match a slate grey roof? 3Apr 13, 2009 10:29 pm Dear Michelle, Thanks muchly! I intend to pickup a sample pot ASAP. Re: External rendering to match a slate grey roof? 4Apr 14, 2009 6:23 pm ![]() Dear Michelle, Thanks muchly! I intend to pickup a sample pot ASAP. Thank you for replying Boris T Bear….its refreshing to have someone who has not posted before to say thank you! ![]() Internal and External - Building and Colour Consultant Online - Worldwide Re: External rendering to match a slate grey roof? 5Apr 20, 2009 8:56 pm Dear Michelle, The Silkwort matches well, but we wondered whether we should try a warmer colour and would love your thoughts on colourbond Dune as an alternative render. And if we were to go with Dune (or a similar colour), should we change the colour of the aluminium window frames? We are worried that having metallic silver frames restricts our choices of render colours. I've attached the Rylock metallic silver sample. (Mind you, the attachment doesn't really do it justice) Would white aluminium window frames be a better/safer option? Irrespective of what colour render we eventually choose? Thanks Boris and family Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: External rendering to match a slate grey roof? 6Apr 20, 2009 9:02 pm I don’t have a problem with silver windows; to me they go with everything. Bit like having a soft grey really. Also….Dune is one of my all time fav colours, it just goes with everything! I would stay with your original windows, 2 reasons. 1) they will be cheaper 2) they should be fine. Internal and External - Building and Colour Consultant Online - Worldwide Re: External rendering to match a slate grey roof? 7Apr 22, 2009 5:18 pm Dear Michelle, Thanks again. We think we'll go with Dune for the walls, downpipes, and Dutch gables. and 1/2 strength Dune for the eaves. (I've always wondered why many recommend reducing the strength for the eaves) We'll post our house when it is finished - hopefully sometime around Xmas. Cheers Boris and Barbara I would probably render it and then paint it as per your other advice, or gyrpock over the top. 1 15041 ![]() To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 11517 ![]() just pull up the slate. If you go over the top, your tiles would not have an even surface to be glued to. Im no tiler, but i can imagine a couple of things being an issue… 1 10667 |
