Browse Forums Interior Decorating Lounge Re: Low futon couch? 3Mar 15, 2009 8:57 pm misskittyfantastico This might be right off track but......... you dont happen to mean 'Thai Triangular cushions' do you?? not sure how to make the photo appear in this post but if you click on the download link the image will come up ......hopefully Thanks for the effort, not quite... it has a solid wooden base, and square cushions that don't cover the base, almost like the base is where you can put drinks etc when you sit on it. Like this, but only 1.5 seater... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 4 6201 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17530 Those span tables can be pushed a little for a low deck if you dont mind a little flex. Last deck I did, I pushed it a little and it was still rock solid - no noticeable… 6 13754 |
