Browse Forums Interior Decorating Lounge 1 Feb 09, 2009 11:25 am I am currently in the process of building my own home, and am after suggestions of render wall colours that will go with a colourbond ironstone roof, also suggestions of window and garage door colours, Please help , someone suggested Gnu tan but not sure if it go. Re: wall colours that suit colourbond ironstone roof 4Feb 09, 2009 12:46 pm kdlh we were after a roof which was dark grey in colour - colourbond reccomeded ironstone, can you suggest something else? thanks Try woodland grey? Re: wall colours that suit colourbond ironstone roof 7Feb 09, 2009 2:46 pm Monument is a very dark charcoal, almost black to me. It's nice!
Woodland Grey is a green grey, and Ironstone has a hint of blue. But not in an awful way! - check out kexkez's posts, I am pretty sure she just had her Ironstone roof installed. Clarity has one too I think. Sorry can't help with wall colours. But would think most colours would go with Monument. Re: wall colours that suit colourbond ironstone roof 8Feb 09, 2009 5:49 pm Hi there
We are building a fully rendered two storey house with an ironstone colorbond roof. The top floor will be rendered in solver vitesse and the bottom floor will be solver kanga. The portico will be in limestone block work. Basically we copied the colours from another house we saw, so should look good. The ironstone is a bluey-grey. We used colorbond Dune for fascias. Hope that helps. Re: wall colours that suit colourbond ironstone roof 9Feb 09, 2009 6:10 pm K…the more questions you ask the more answers you will get and the more confused you will be.
So am I looking better to you now? To help you with your current question I will show you your 2 colours chosen. Ironstone Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Gnu Tan Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: wall colours that suit colourbond ironstone roof 10Feb 10, 2009 11:47 am Thanks for the colour squares, the colour GNU TAN looks quite different than when i saw it on a house. I am after a nice earthy tone, do you happen to have squares of solver-kernel (2714) and balaswood (2713), we are looking at these possibly with fascia being colourbond evening haze. Please provide your opinions/suggestions. thanks for your help Cheers. The painted render is a bit chalky to the touch. To prepare the surface for best adhesion, what would you recommend? Also, given that there must be some… 6 8512 Yes i guess this is one of the main reason as i checked one post foundation 4 9997 Hey. Head to a metal and decide on which profile you will use first. Profiles with larger corrugations can greatly change the appearance of the color in different… 0 3387 |
