Browse Forums Interior Decorating Lounge 1 Jan 09, 2009 2:03 pm Hello All,
Just spoke with the staff in Hopetoun (The do all the colours etc for Porter Davis). The staff also mentioned that these colours have a solver mixed with them (not exactly sure what it does but I am of the belief it lightens the colour) We like the wall colours in two of their display homes. Moondust (We also really like the tiles in this house) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The other colour is called Silky beige Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Just after some thoughts on these colours I like them and so does my partner, not exactly sure what the solver part entails but I'm sure it shouldn't be any problem. Cheers Chris Re: Opinions wanted on two possible wall colours 2Jan 09, 2009 2:09 pm Chris…..can’t see why you would like this house……………….its stunning!
If you take notice of how each of the houses/ photos are decorated you will notice there is 2 styles happening. 1 modern and 1 classic. What type of decorating will you be doing….like the first photo or the 2nd one? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Opinions wanted on two possible wall colours 3Jan 09, 2009 2:25 pm Michelle Chris…..can’t see why you would like this house……………….its stunning! If you take notice of how each of the houses/ photos are decorated you will notice there is 2 styles happening. 1 modern and 1 classic. What type of decorating will you be doing….like the first photo or the 2nd one? We are more likely to be along the more modern style of home in he first picture. I really like in both the pictures the contrast against the white cornice and feature columns (both homes have them). I personally think the moondust colour will work better with the tiles (obviously PD thought so as well and matched them) - On the other hand I think those tiles will cost an arm and a leg and may be outside our budgeted range won't know that until tomorrow when we visit national tiles. Re: Opinions wanted on two possible wall colours 5Jan 09, 2009 2:35 pm Ha you see my problem building with PD and keeping in my budget!
I walk through the displays homes which are generally immaculate and go oooh I like that and oooh this as well! Re: Opinions wanted on two possible wall colours 6Jan 09, 2009 2:43 pm Well that was easy, I'm going to paint my entire house Silky Beige .
Both look lovely but I like the warmth of the second one, the first appears cooler to me. Building Upside down house in Wantirna VIC Current Stage: Procrastination... it's just all too hard.... Blog: http://thereluctantbuilder.blogspot.com/ Re: Opinions wanted on two possible wall colours 7Jan 09, 2009 2:45 pm I’m going to say the Moondust as well. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Opinions wanted on two possible wall colours 10Jan 09, 2009 6:35 pm Michelle I’m going to say the Moondust as well. Michelle do you have moondust on any of your colour cards? Just looking at the ones I have I cannot find it anywhere. Re: Opinions wanted on two possible wall colours 11Jan 09, 2009 6:39 pm You’re in luck, and this doesn’t happen very often.
It’s a Bristol colour. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Opinions wanted on two possible wall colours 13Jan 09, 2009 7:05 pm Michelle You’re in luck, and this doesn’t happen very often. It’s a Bristol colour. Thanks Michelle! I also just found it at Haymes paint number 4051. yes it is possible but watch for noise transmission, decouple as best you can. Maybe wider top and bottom plates with 70mm studs to allow the cabinet to be recessed fully 1 6636 You can wash over existing pavers with 10% solution of water and hydrochloric acid, then wash off. The acid will provide for required bond key with new concrete. 1 36960 0 9810 |
