Browse Forums Interior Decorating Lounge 1 Dec 10, 2008 10:53 am Hi, I keep reading about these drapes that everyone loves but don't understand how they work having a bit of a dumb moment.
So are they like vertical blinds enclosed in a sheer curtain? Do you use a wand like an ordinary vertical to close the "blades" and therefore make it darker? Some things are worth waiting for. Re: How do Luminettes work? 5Dec 10, 2008 7:50 pm kyton I am in the same boat as you. I am intending to go to a showroom soon to see them in person, I think that might be the only way I will fully understand! It might not be for a while though, so lucky I've got my redi shades for the interim Re: How do Luminettes work? 6Dec 10, 2008 8:49 pm If you download the Luxaflex brochure (on the right hand side of the Luminettes page), it does give a better explanation of it, but really probably better to see it in person, as donuts says. Re: How do Luminettes work? 7Dec 11, 2008 9:00 am In short….Luminetts are basically a really classy vertical, (they work the same way) with a soft layer of fabric connecting it all together.
Does that help?? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Block of two storey townhouses requires painting on the roof. A brick parapet wall separates each unit and extends above the tiled roof. The parapet walls require sealing… 0 3503 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 10098 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 3597 |
