Browse Forums Interior Decorating Lounge 1 Nov 20, 2008 8:48 pm Hi, I was just looking through some houses for sale and noticed this one and its feature paint above the kitchen cupboards
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Does that look silly? Anyone seen anything like this done? My kitchen has a similar space above the kitchen cupboards and a lowered roof: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I'm currently having white for everything, could I do something like the above and would it look ok if it was the only feature area/wall? Custom build! Re: Feature wall, but not really a full wall 2Nov 20, 2008 9:15 pm I think the space above your cupboards looks a lot smaller so it might look a little odd to have a small strip that's a different colour.
At what point would you cut it off on the edge as well? It looks like their colour stops at the end of the room whereas your kitchen wall seems to join in with another room... If that makes sense Re: Feature wall, but not really a full wall 4Nov 20, 2008 9:20 pm donuts I like it when the splashback colour is brought up above the cupboards and on the whole wall as a feature wall. But that is totally different to your idea! I'm having large white tiles for my splashbacks Re: Feature wall, but not really a full wall 5Nov 20, 2008 9:23 pm bev I think the space above your cupboards looks a lot smaller so it might look a little odd to have a small strip that's a different colour. At what point would you cut it off on the edge as well? It looks like their colour stops at the end of the room whereas your kitchen wall seems to join in with another room... If that makes sense Understand what you are saying. It is joined onto the lounge room. What if I did the lowered roof bit as well? Or/And stopped the colour where the roof goes back to normal? and went down the wall next to the cupboards and down along the bench? Ps.... that isn't my exact kitchen its pretty close, I'm not having the raised bench bit, I cut that off so I have a level bench. Re: Feature wall, but not really a full wall 7Nov 21, 2008 9:45 am can i ask why you dont have a bulkhead on the top of the cupboards,? it is a really small space. if you have a bulkhead you wont have to keep dusting the top of the cupboards.
I know that on top of my cupboards above the rangehood it even gets greasy (yuk). Maleena Hardy Curiouser & Curiouser Vintage-Handmade-Interior & Colour Consultancy http://www.curiouserandcuriouser.com.au Re: Feature wall, but not really a full wall 8Nov 21, 2008 10:35 am MaleenaH can i ask why you dont have a bulkhead on the top of the cupboards,? it is a really small space. if you have a bulkhead you wont have to keep dusting the top of the cupboards. I know that on top of my cupboards above the rangehood it even gets greasy (yuk). Not sure Maleena, its just the design the builder is using I guess. Don't know if it has something to do with the lowered roof bit?? Custom build! Re: Feature wall, but not really a full wall 10Nov 21, 2008 12:57 pm No you can’t put colour there, there is no cut off point to stop the paint on the left side wall, it will look funny
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Feature wall, but not really a full wall 11Nov 21, 2008 1:00 pm Michelle No you can’t put colour there, there is no cut off point to stop the paint on the left side wall, it will look funny Thanks Will see if I can get it filled in. Custom build! do not pay until you are satisfied with workmanship windows require flashing over the head archithrave and up under weatherboards 3 28287 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 3597 My door tends to rub against the frame during winter and I'm looking to fix it so it closes smoothly. Looking online on Youtube I'm seeing methods to fix the alignment and… 0 700 |
