Browse Forums Interior Decorating Lounge 1 Oct 10, 2021 11:50 am I have a timber ceiling that has discoloured due to age and nicotine. I had the floors redone (second pic) and now need ideas for the ceiling. I am planning white walls and charcoal/black window trim. I want to paint the beams charcoal/black but not sure what to do with the wood in between that will complement the floors. Should I just paint? White? Or another colour that will fit with the black and white of the walls and trim? Cover with panels? Should I try and remove the stained lacquer and leave bare? Whitewash? Or can I just leave it? Does it look so bad contrasted with the floors? I would be grateful for all ideas or suggestions from both a practical and aesthetic perspective! By the way - this ceiling is throughout the entire house and is extremely high! Thank you for your wisdom! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thank you @ashington Homes for your reply! They just got back to me and offered credit for me to just take it as is. It was a less than quotes I got from ceiling… 6 2927 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6645 Hi guys We have just removed a very large grape vine which was mounted to a structure along this wall. This is a shared wall with our neighbour, and after removal, we… 0 4171 |
