Browse Forums Renovation + Home Improvement 1 Jul 12, 2020 10:08 am My house is very dark from the outside. The eves or roof extends 2.5 meters out. I could do with some suggestions on how to lighten it up. Thank you. Brick and wall. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ EvesLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Dark Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Dark house. 3Jul 13, 2020 2:39 pm ![]() Velux skylights are the best. We added 2 to our old kitchen - they brightened up the area dramatically, and the light well in the ceiling made a nice architectural statement. Thanks you for your reply. I have a few inside the house and they are great. It was more the outside appearance I was referring to. Re: Dark house. 4Jul 13, 2020 7:35 pm a more economical option would be to replace some panels of roofing with panels of Polycarbonate transluscent roofing..try narrow panels in line with windows and keep in mind that transluscent panels of roofing can overheat if too wide so test a single sheet before adding more panels..and depending on how you use the verandah and how much shelter you need/want consider removing sections of roofing and make the bare frames into a pergola covered with deciduous vines to create summer shade Re: Dark house. 5Jul 13, 2020 7:56 pm ![]() a more economical option would be to replace some panels of roofing with panels of Polycarbonate transluscent roofing..try narrow panels in line with windows and keep in mind that transluscent panels of roofing can overheat if too wide so test a single sheet before adding more panels..and depending on how you use the verandah and how much shelter you need/want consider removing sections of roofing and make the bare frames into a pergola covered with deciduous vines to create summer shade Thank you that’s great, definitely food for thought. Re: Dark house. 7Jul 13, 2020 8:10 pm Thank you. The sky lights were mentioned before Inside. I can see there the difference it makes outside as well. Hello, Old post but just saw this. Wondering what you ended up going with, as I'm currently trying to pick out of this range also, and it always looks different to what… 1 1837 Looking for some grey ideas not too dark. Would like a different colour for a feature wall. Our kitchen is dark brown. I need so help if anyone can share some ideas/photos 0 965 |
