Browse Forums Renovation + Home Improvement 1 Jun 10, 2020 7:32 pm Hi Guys, We are planning an extension soon. We have a pergola which was converted to a sunroom before we bought the house. Is there any way to install a plasterboard ceiling to the colourbond roof? How can we fix studs to the colourbond without water coming through. Any advice from Builders or Serial renovators would be great. If you any any other ideas, please feel free to share. Thanks, F Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Installing plasterboard ceiling to colourbond pergola 2Jun 10, 2020 8:51 pm ![]() Is there any way to install a plasterboard ceiling to the colourbond roof? How can we fix studs to the colourbond without water coming through. You could lift the roof and install batten to the frame, then fix the roof back down to the battens. Roofing material is routinely screwed down, although you'd need to seal the fasteners. I have a sunroom ceiling that needs replacing. Has very little clearance (65mm at its lowest) and a colorbond roof. Anyone got any ideas? Got a quote for a versiclad… 0 825 DIY, Home Maintenance & Repair Hi there, hubby and I are insulating our garage. It shares a wall with neighbouring garage. Party wall is single stud frame. The neighbours switchboard is on the… 0 858
Thanks for this mate. I might look to go down this route 24 4602 |
