Browse Forums Renovation + Home Improvement 1 May 01, 2020 6:57 pm Hi I live in an area that doesn't have town water and the metal tap at the bottom of one of my tanks rusted through and sprung a leak, and it looked like it was under pressure. I used plumbers tape to stop the pressure then used apaint on mastic sealant to stop the leak. Problem now is that i have a slow leak and I tried more sealant but it doesn't plug the wet surfaces. Is there a product that can be used on wet surfaces to seal it completely or do I have to do something else? Cheers Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Mark Re: how to plug a water tank leak 2May 01, 2020 8:25 pm I would try dill a tap a thread, use a screw with silicon on the thread. Re: how to plug a water tank leak 3May 03, 2020 5:43 am You may solve this problem only at $10.5. Go to Amazon and order quick steel putty. I have the same problem previously one of my friends suggest me to use that. And i got good feedback. You may try this, https://www.amazon.com/Blue-Magic-QuikSteel-Steel-Reinforced/dp/B07GSHZMPW If you make sure all taps inside and out are turned off, what does the water meter show if you leave it for a while. 2 20235 Hi all, I am hoping someone has some ideas as to what is causing my bathroom leak. The leaking appears to mainly happen when we turn the sink basins on. It takes a while… 0 5084 DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 17322 |
