Browse Forums Renovation + Home Improvement 1 May 01, 2020 5:27 pm Is it possible to put up weatherboard/timber cladding over the top of rendered brick? Or would the render need to be removed first? Re: Cladding over rendered brick? 2May 01, 2020 6:40 pm I don't think you'll need to remove it, it's gonna drill the holes through some bricks and fix the timber on micwallpaper.com.au Picture your wall to a view Cheers. The painted render is a bit chalky to the touch. To prepare the surface for best adhesion, what would you recommend? Also, given that there must be some… 6 1619 The spacing of the studs looks pretty large especially for a load bearing wall. 3 8216 |
