Browse Forums Renovation + Home Improvement 1 May 01, 2020 5:27 pm Is it possible to put up weatherboard/timber cladding over the top of rendered brick? Or would the render need to be removed first? Re: Cladding over rendered brick? 2May 01, 2020 6:40 pm I don't think you'll need to remove it, it's gonna drill the holes through some bricks and fix the timber on micwallpaper.com.au Picture your wall to a view Well I retract my first post then. Clad the top and render both levels. By the time it is all painted , it will tie both levels together. I hate driving along and seeing… 5 1274 DIY, Home Maintenance & Repair I think/hope you're right. Any recommendations for a good binder sealer? Also any suggestions on what I should use to fill the imperfections on the finish (I was just… 3 2593 Hi guys, I've got an older bathroom with wall and floor tiles. The floor tiles run along the wall as a skirting and then the wall tiles are above all the way to the… 0 4127 |
