Browse Forums Renovation + Home Improvement 1 Apr 26, 2020 8:28 pm I have a sunroom ceiling that needs replacing. Has very little clearance (65mm at its lowest) and a colorbond roof. Anyone got any ideas? Got a quote for a versiclad product called Ceilink which is great but a little expensive for what we need. Just want to freshen up the room. It will probably get knocked down I the next few years for an extension. Thanks You could lift the roof and install batten to the frame, then fix the roof back down to the battens. Roofing material is routinely screwed down, although you'd need to… 1 967 Once the sun is inside the building you are limited in what you can do. Try to shield it outside, easier anyway I think. 3 3248 ![]() 18 4315 ![]() |
