Browse Forums Renovation + Home Improvement 1 May 30, 2023 12:54 pm We have an old 1960's 2 story red brick house on a large 1500 sqm block and are looking at options to renovate. Ceiling heights are a major issue as we want to flip living area to downstairs (currently a low celiing garage/rumpus), and replace garage doors with glass panels/sliders to open to outdoor living area.... We also want to replace old brick/tile roof to a more modern/flat roofline or camoflage it somehow. Option One - is to create a void in the top floor of the house and relocate bedrooms to a new "wing" extending the footprint of the house. Keep existing roof and update eves. Option Two - is to gut the entire top floor of house, remove roof and extend walls up 2 metres and then reinstall flooring with a 3 mtr roof height downstairs living, 2.7 mtr upstairs bedroom. Hope this makes sense. Am I crazy? I am wondering if anyone has considered anything similar and if there is a significant cost differential? Thanks so much in advance. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Replace roof, raise wall height vs extend 2May 30, 2023 1:39 pm It will be cheaper to knock it down and start again. You will also end up with a better product that is designed from the start to fit exactly what you want rather than trying to "make"something work. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 You should pressure clean your roof first and make sure the paint you buy also is anti mould. 4 21180 Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust… 1 10720 i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 13445 |
