Browse Forums Renovation + Home Improvement 1 Oct 07, 2019 9:13 pm Hi guys, we are planning on extending our current house to accomodate an attached granny flat. I wanted to know how much it would cost to put a standard 900mm door through a pre existing brick wall. The wall does not have a steel beem through it. Also how much would it cost to put a bathroom (vanity, toilet and shower) in what is currently our lounge room? Thanks a tonne guys! Re: Cost of putting a door in a brick wall 2Oct 07, 2019 9:14 pm Manny007 Hi guys, we are planning on extending our current house to accomodate an attached granny flat. I wanted to know how much it would cost to put a standard 900mm door through a pre existing brick wall. The wall does not have a steel beem through it. Also how much would it cost to put a bathroom (vanity, toilet and shower) in what is currently our lounge room? Thanks a tonne guys! Edit: we are planning a bathroom of 1500mm by 3000mm in size with standard fixtures Re: Cost of putting a door in a brick wall 3Oct 09, 2019 6:54 am Manny007 Hi guys, we are planning on extending our current house to accomodate an attached granny flat. I wanted to know how much it would cost to put a standard 900mm door through a pre existing brick wall. The wall does not have a steel beem through it. Also how much would it cost to put a bathroom (vanity, toilet and shower) in what is currently our lounge room? Thanks a tonne guys! Manny007 Edit: we are planning a bathroom of 1500mm by 3000mm in size with standard fixtures Unfortunately, this is a bit of a "how long is a pice of string" question, because this will very much depend on your specific circumstances. I suggest you will need to get a quote from a couple of builders, and there may be some engineering required too. DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 17322 Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks 3 7944 |
