I bought my first property and because the house basically has almost more windows then walls, I would be happy to cover one window in temporary/ permanent way.
I tinted the glass mirror, from outiside can’t see anymore inside.
Now the second step would be just cover the window , with plasterboard or 3D wall sheet.
Basically the window will be just covered, in future , in case would be still ok to remove everything and comeback normal.
I would be able to that or I need some permission for cover a window?
The property will be rented , I know in case of open new windows need permission , probably in case close permanently the window with brick maybe need permission, but close only from inside example with plastic 3D wall? Will still need permission? I will have some problem against the law?
Cover that window , will create a perfect zone for tv and I will be able to install bigger kitchen and everything will looks good and more functionality.
