Browse Forums Renovation + Home Improvement Re: Cracks in internal walls - who do I get to have a look ( 2Apr 08, 2019 12:13 am felant Who can I get to have a look to find if there is a problem which needs fixing? You could get a building inspector out to have a look, the same as you do when you buy a new home. They should be able to tell if any repair work is required. The spacing of the studs looks pretty large especially for a load bearing wall. 3 11108 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17195 Do you have a scope of works? If have texture on wall now, the patch will show through The standard for repair of texture is to patch, re-texture corner to corner,… 5 6909 |
