Browse Forums Renovation + Home Improvement 1 Feb 02, 2019 8:42 am I have been tryimg to find if/how this can be done. The doors in our house are the exact same timber frame as the fixed windiws, its only the frame that is different. Can anyone tell me, have you converted any full height timber windiws into swing (french) doors? Here is a photo of a dooe and a window. I know the correct procedure is to replace the entire frame, but we cant afford to, are very unlikely to get a good match (these cedar wimdows and doors are 25yo) and it seems like such a waste of beautiful windows. Any advice is appreciated! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Converting timber windows into doors 3Mar 28, 2019 5:46 pm Hello LH4545, this is easy done as long as the width remains the same. What happens is you have a lintel above the window that takes the roof load and transfers the load accross the top of the window using the lintel, and onto the studs either side of the window. This is known as "Load Transfer" So, as long as you dont need to go wider, you can easily remove the bricks below and install your door Good luck! 2 7938 If I hire a contractor to convert a window to a sliding door will I need to show them Council approval paperwork? That is, if I want to take a risk of carrying out the… 0 650 I don't know them all, the first 2 top of your list are best known. Rylock is a good company, Stegbar is for sale. 4 12819 |
