Browse Forums Renovation + Home Improvement 1 Oct 23, 2018 8:49 am I'm about to renovate our kitchen and would like to change the layout of the island bench slightly. Problem is that to do that we need 9-10 more ceramic floor tiles, and I used our last spares in a bathroom renovation a couple of years ago. However there are tiles within cupboards that I could use if they can be lifted out without damaging them. The tiles are laid on a cement screed substrate and extend throughout most of the house so replacing them is not a (palatable) option. Is there anyone in Melbourne who provides a service to remove floor tiles undamaged, for reuse? Re: Lifting floor tiles for reuse 2Oct 23, 2018 10:01 am Stevo61 Is there anyone in Melbourne who provides a service to remove floor tiles undamaged, for reuse? Iām sure there are some that would give it a go, but I doubt anyone would give you a guarantee they could lift all or any intact. Re: Lifting floor tiles for reuse 3Oct 26, 2018 9:51 am Hi Stevo, It really depends on how well they are glued down. When I lift tiles it is ALWAYS a bit of a gamble how easily they come up. For example, in a reno we recently did, it took 3 days for our demo crew to pull up a unit worth of floor tiles. They would chip, break and not come up. Glued really well! Can I offer you some potential alternatives? 1. Is there definitely no opportunity to match the tiles? Different batches may have slight colour variations, but this COULD be un-noticable. 2. If the tiles can't come up. Could you re-tile with a totally different 'feature tile'? Hope this helps! Danny. Re: Lifting floor tiles for reuse 4Oct 29, 2018 9:53 am RenoMentor Hi Stevo, It really depends on how well they are glued down. When I lift tiles it is ALWAYS a bit of a gamble how easily they come up. For example, in a reno we recently did, it took 3 days for our demo crew to pull up a unit worth of floor tiles. They would chip, break and not come up. Glued really well! Can I offer you some potential alternatives? 1. Is there definitely no opportunity to match the tiles? Different batches may have slight colour variations, but this COULD be un-noticable. 2. If the tiles can't come up. Could you re-tile with a totally different 'feature tile'? Hope this helps! Danny. Hi Danny, Thanks for your suggestions. I've looked for matching tiles but they're more than 20 years old and even the tile remainder shop in Bayswater (Melbourne) didn't have them. We bought them from the importer so it's possible they weren't even available elsewhere back then. Feature tiles are also out because it's only one small area of the kitchen and I'm not about to replace perfectly good tiles to make it look like it wasn't a patch-up job. Meanwhile, I started working on getting some tiles out of the cupboard myself. I'll post how I did it in this discussion. Cheers, Stevo Re: Lifting floor tiles for reuse 5Oct 29, 2018 10:18 am Over the weekend I had a go at doing this myself and have lifted one tile so far! In case anyone wants to try this themselves, here's what I did:
Here's a photo showing the "job site" with the score and snap knife and the grout saw: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ They make the room much easier to clean for one, reflect more light (if light colour tiles are used), and you dont end up with dust on the top edge of tiles (cause most… 3 9618 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 419 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16567 |
