Browse Forums Renovation + Home Improvement Re: Extending a steel frame home 2Jul 16, 2018 8:09 am Yes, I'm doing the designs, engineering & Costings for one at the moment (OB) in perth/guldford It depends on your design? More info required You will need to leverage the advantages of the materials & Labour used, ie, Span/Weight/Cost, trusses,etc They are called Steel Frame fixers, get on site fabricators as opposed to factory... unless you have a workshop/skills? Cheers Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14449 This is 100% true. You can not hang anything on steel frames. very frustrating 8 8033 Hi, I have a steel frame house which was built 2 years ago. When you are down stairs you can hear clunking noises when someone is walking around. We were told if you… 0 4461 |
