Browse Forums Renovation + Home Improvement Re: Replacing Solid Door w Sliding 2May 17, 2018 7:17 pm coldestwinter Is it structurally possible to somehow remove these, cut out the brickwork below the awning window and replace with a glass sliding door? Anything is possible if you are prepared to pay. If your wall is non-load bearing, then all you would need to support with a lintel are the bricks above the window (lintel probably already exists). If load bearing, then you might need to strengthen the wall a bit. If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8251 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16091 |
