Browse Forums Renovation + Home Improvement Re: Concrete Garage 3May 10, 2018 4:54 pm StructuralBIMGuy @Mark_J Why concrete is it above or below ground, Reinforced or not? More info required BTW sketches also help Hi Thanks for the reply. The garage will be at ground level and is purely for the look instead of rendered blockwork or timber. It will be a 6 x 6 garage with a second timber level on top. So fairly straightforward on level ground. I'm trying to get an idea of the Sqm pricing. Cheers Re: Concrete Garage 4May 10, 2018 7:19 pm From my experience concrete finishes look crap unless you opt for architectural off form finish in which case it becomes very costly. Off form concrete finish is used in signature buildings where pockets are deep. It requires meticulous design and detailing and an experienced (commercial) builder to match. You are already asking for price which tells me you can't afford it. Stick to masonry finish or have it rendered and spend your money on more worthwhile wow feature. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Concrete Garage 5May 12, 2018 9:14 am Mark_J Try reinforced concrete (60mm) veneer over brickwork DIY will save on the labour costs The brickwork will provide the form for the inside of the garage Reusable formwork and DIY concrete (20,10,100) is cheap, but labour intensive as you'll have to do it in sections let me know if you need the details Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Concrete Garage 7May 14, 2018 7:31 pm Mark_J I am happy to assist & you seem keen on a concrete finish You will need to use wire ties protruding (say 25mm) from the brickwork/blockwork to attach the reinforcement mesh make sure you allow 30mm concrete cover to the formwork Try Nylon Electrical Cable ties to secure the formwork to the wire ties...this might need tweaking .. do a sample panel first.. The concrete will bond to the bricks, the wire ties will add shear reinforcement (Planar) and the reinforcement will hold it together should you get shrinkage cracks... not sure what sort of joint you want between panels? hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Concrete Garage 8May 14, 2018 7:57 pm I guess it might be better to consider using ICF (insulated concrete forms blocks) such as Zego HomeFORM or Zego ReFORM (the later will provide the concrete surface looks you are after) (zego.com.au). Alternatively, you chose the one with insulation and render on top. You should be looking into around $140 per sq m + GST for carpentry labour and blocks themselves + add concrete, reo and pump costs on top. Acrylic render or masonry finish - another $50-60 per sq m + GST. So let's say 6x6 sq m garage walls (2.8 m height) minus opening for 2,4x4.8 garage door will be costing you 2.8x6*4-(2.4*4.8 )*$250=~$14K supply & installed (with one side rendered). If you want to stick to insitu concrete, then you would have to invest into formwork and full structural engineering (for existing ICF blocks it is already pretty much defined, but you would still require certificate). Re: Concrete Garage 9May 14, 2018 9:43 pm StructuralBIMGuy @Mark_J I am happy to assist & you seem keen on a concrete finish You will need to use wire ties protruding (say 25mm) from the brickwork/blockwork to attach the reinforcement mesh make sure you allow 30mm concrete cover to the formwork Try Nylon Electrical Cable ties to secure the formwork to the wire ties...this might need tweaking .. do a sample panel first.. The concrete will bond to the bricks, the wire ties will add shear reinforcement (Planar) and the reinforcement will hold it together should you get shrinkage cracks... not sure what sort of joint you want between panels? hth Thanks for the reply I appreciate your time. I think I might just get the block work done around the sides and get some guys to form up and do the concrete. To be honest the cost is not really the issue I am just putting a budget together for a rebuild and am after a defined contemporary look with the concrete and wood. I haven't had the formwork for the walls done before so was unsure of cost per SQM. Re: Concrete Garage 10May 14, 2018 9:45 pm alexp79 I guess it might be better to consider using ICF (insulated concrete forms blocks) such as Zego HomeFORM or Zego ReFORM (the later will provide the concrete surface looks you are after) (zego.com.au). Alternatively, you chose the one with insulation and render on top. You should be looking into around $140 per sq m + GST for carpentry labour and blocks themselves + add concrete, reo and pump costs on top. Acrylic render or masonry finish - another $50-60 per sq m + GST. So let's say 6x6 sq m garage walls (2.8 m height) minus opening for 2,4x4.8 garage door will be costing you 2.8x6*4-(2.4*4.8 )*$250=~$14K supply & installed (with one side rendered). If you want to stick to insitu concrete, then you would have to invest into formwork and full structural engineering (for existing ICF blocks it is already pretty much defined, but you would still require certificate). Thanks Alex I had been looking into the insulated foam blocks as seen the HomeForm ones in the UK. This is something I need to look into further. Thanks for the reply and info. Re: Concrete Garage 11May 15, 2018 2:13 pm Mark_J It doesn't have to be Brickwork internally ? Why not use a Lysaght Colorbond Profile internally as part of the formwork That would be a Fantastic Contemporary wall look ie Colorbond internally &, Concrete & Timber externally and I am happy to give you the details...lol, If you promise to put up the photos when completed? Hmmm..Thats a fair swap Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Surrey Hills, Vic 3127 Garage is being built with metal, 3m distance away from my cover deck. It is parallel to my cover deck, living room, family room and kitchen,… 0 7036 |
