Forum Renovation + Home Improvement Re: Rear Extension - Value to Home (Garden Concerns) 2Apr 21, 2018 10:11 am lonelydove IMO it is of little concern if you lower or raise the ground level as you will need to address Geo/Soil, retaining and stormwater disposal, it is of concern if your designer or builder leaves you in worse position than when you started, after the build...? BTW Photos do help Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs https://plus.google.com/u/3/communities ... 1476023758 No much bias there. I have found that the concreters that I have engaged to do set out of form are relatively good at what they do. I run around and check with a water… 6 774 ![]() Hi there, does anyone know of a good Adelaide home extension company that will build a master bedroom plus ensuite in brick for a good price? 0 224 10 1116 |
