Browse Forums Renovation + Home Improvement 1 Apr 13, 2018 11:26 pm My husband and I are considering a renovation to open up the house to the yard, as we need the extra living space but have a small 3br house. We want to minimise structural changes and stick within the current footprint. Current plans Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Suggested plans Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Key changes are swapping the kitchen and dining spaces, removing part of the existing kitchen wall, moving the laundry door, replacing the back door and kitchen window with a French door and building a deck. My concerns are how narrow the kitchen will be (3000mm) particularly the walkways (950mm), that access to the back door will only be via the dining room, that the stove will have a full height window splashback )not sure how we would install a range hood)and the cost of removing the section of wall (how do I determine if it’s a load bearing wall? Re: Renovation floor plan thoughts 2Apr 15, 2018 7:55 am Firstly, determine what type of roof structure you have Try Using a broom to lift the manhole cover up , if its too dark to see, attach/tape mobile phone to another broom with torch and video turned on Review Video for Roof frame type Truss Roof Very High possibilty Internal walls are non-load bearing pitched rafters , under purlins and struts Hgh possibility that the internal wall will support a Strut/Strutting Beam and is load bearing Raked Rafters/Ceiling very Hgh possibility that the internal wall is load bearing Finally, the only way to be 100% sure is to get a photo of the wall from within the roof and upload .BTW, Photos of the roof from above also sometimes helps ...try google Google satellite Maps Here's a tip for figuring out rooms layouts.. rather than using a phone 2D app try Sketchup 3D and post back with the 3D Model for the 3D Bim Structurals hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Renovation floor plan thoughts 3Apr 16, 2018 2:00 am Thanks for the reply, I’ve been playing with sketchup and it’s taking me ages to get a plan drawn up. I’ve climbed up into the roof, we have a hip roof with purloins resting on the wall I’m wanting to remove, though not in the section I’m wanting to remove. The wall I’m wanting to move a door in is also load bearing. I presume this means I’ll need to have engineering done and have plans drafted. Re: Renovation floor plan thoughts 4Apr 16, 2018 7:27 am Red Smarties The wall I’m wanting to move a door in is also load bearing. I presume this means I’ll need to have engineering done and have plans drafted. Yes, it will need a support beam/truss if there are strutting posts within the roof, hence engineering Make sure you can understand and quantify the changes Knockdown and Rebuild Upgrades Costs discussed here You can get someone to model it for you..the 3D Model comes in handy on site during construction and inspections. BTW Photos do help otherwise everyone reading may be guessing? Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Renovation floor plan thoughts 5Apr 16, 2018 10:28 am StructuralBIMGuy Red Smarties The wall I’m wanting to move a door in is also load bearing. I presume this means I’ll need to have engineering done and have plans drafted. Yes, it will need a support beam/truss if there are strutting posts within the roof, hence engineering Make sure you can understand and quantify the changes Knockdown and Rebuild Upgrades Costs discussed here You can get someone to model it for you..the 3D Model comes in handy on site during construction and inspections. BTW Photos do help otherwise everyone reading may be guessing? Unfortunately the spot I need to photograph is covered by blow in insulation and an aircon duct. This is the best pic I could get. It is of the start of the point I want to remove, the second pic looks toward the outer wall, along where I want removed. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 11252 we need accurate dimensions as well as the number of bedrooms and bathrooms needed etc to make specific suggestions but, based on estimated rooms sizes, it could be… 1 547 i thought the flipped plan initially but bec i want narrow pathway from entry to dining (dont like bend), also cannot fit the… 7 17278 |
