Browse Forums Renovation + Home Improvement 1 Mar 21, 2018 9:31 pm Hi, We're in the middle of a big reno and we painted all the eave sheets with 2 coats of exterior acrylic on the weekend ready for the builders to put up on Monday. Unfortunately they didn't go up and it has been raining for the past 2 days and all the sheets have been out in the rain. Just wondering if they will be OK or will they need to be repainted? Thanks you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 3773 Old Home Restoration / Renovation Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts 0 8798 First time building. this triangular part (marked in red) behind my two bedrooms does not have external wall bec of Alfreco roof… 0 640 |
