Browse Forums Renovation + Home Improvement 1 Mar 01, 2018 10:36 am Hello, we are a married couple in our 30s who are going to attempt to renovate our country home over the next 2 years. We are just after some advice along the way and assistance. Our first plan is a heat transfer system kit, which will flow from the fire to our 2 children''s bedrooms. Then we are going to replace carpet. First up, I see Bunnings have Air Transfer Kits for $300, others are $800 online. Any advice on this.... Thanks. Re: Home Renovation (first time) 2Mar 01, 2018 12:46 pm Hi Brendon Welcome to the forum If you have any specifications on the advertised systems Check out the Fan & Motor sizes, airflow rates, ducting size,and reviews,etc There are a lot of variables that you need to consider. ie, Air mixing, opening windows to improve Circulation ,etc Prices aren't indicative of quality & efficiency Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Home Renovation (first time) 3Mar 01, 2018 1:23 pm Item is suitable for a Two Room Transfer Kit Kit includes: 1 x 200mm Industrial Fan 1 x 6 meter , 200mm Insulated Flex duct 2 x 6 meter , 150mm Insulated Flex duct 1 x 200mm Round Grill ( Open or close) 2 x 150mm Round Grill ( Open or close) 1 x Y-Piece ( 200x150x150) Application:
Parameter:
Is a 200mm fan kit the go or 150mm fan kit. rooms are 4 x 4m approx. Re: Home Renovation (first time) 4Mar 01, 2018 1:27 pm https://www.bunnings.com.au/blauberg-15 ... t_p4420513 The one above is a Bunnings one 150mm. Not sure whethere to buy from Bunnings or not. Re: Home Renovation (first time) 5Mar 01, 2018 10:35 pm Brendon thanks for the info The bunnings link is to an exhaust Fan? See if you can track down a "Two Room Transfer Kit" with a Lower decibels noise rating and lower extraction rate (m3/hr) & Velocity (m/s). Alternatively make your own use a variable speed fan. hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs So it looks like we finally have some movement on site! Definitely later than expected, but I'll take any progress at this point. I'll drop by over the weekend to get… 5 27693 Can anyone give me any onfo on New Homes WA? Good or bad, hopefully good just need to know if my choice was good or not? Thanks ❤️ 0 8936 a building inspector should be able to tell you about any major problems but we need a floor plan with dimensions to clarify options for extra bedrooms ... sometime an… 1 8718 |
