Browse Forums Renovation + Home Improvement 1 Mar 01, 2018 10:36 am Hello, we are a married couple in our 30s who are going to attempt to renovate our country home over the next 2 years. We are just after some advice along the way and assistance. Our first plan is a heat transfer system kit, which will flow from the fire to our 2 children''s bedrooms. Then we are going to replace carpet. First up, I see Bunnings have Air Transfer Kits for $300, others are $800 online. Any advice on this.... Thanks. Re: Home Renovation (first time) 2Mar 01, 2018 12:46 pm Hi Brendon Welcome to the forum If you have any specifications on the advertised systems Check out the Fan & Motor sizes, airflow rates, ducting size,and reviews,etc There are a lot of variables that you need to consider. ie, Air mixing, opening windows to improve Circulation ,etc Prices aren't indicative of quality & efficiency Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Home Renovation (first time) 3Mar 01, 2018 1:23 pm Item is suitable for a Two Room Transfer Kit Kit includes: 1 x 200mm Industrial Fan 1 x 6 meter , 200mm Insulated Flex duct 2 x 6 meter , 150mm Insulated Flex duct 1 x 200mm Round Grill ( Open or close) 2 x 150mm Round Grill ( Open or close) 1 x Y-Piece ( 200x150x150) Application:
Parameter:
Is a 200mm fan kit the go or 150mm fan kit. rooms are 4 x 4m approx. Re: Home Renovation (first time) 4Mar 01, 2018 1:27 pm https://www.bunnings.com.au/blauberg-15 ... t_p4420513 The one above is a Bunnings one 150mm. Not sure whethere to buy from Bunnings or not. Re: Home Renovation (first time) 5Mar 01, 2018 10:35 pm Brendon thanks for the info The bunnings link is to an exhaust Fan? See if you can track down a "Two Room Transfer Kit" with a Lower decibels noise rating and lower extraction rate (m3/hr) & Velocity (m/s). Alternatively make your own use a variable speed fan. hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs A quick update, we didn't have site start before Easter. Summit can't seem to give me a day when they are scheduled to begin, so I'm left with a vague "within 10-20… 4 26734 Can anyone give me any onfo on New Homes WA? Good or bad, hopefully good just need to know if my choice was good or not? Thanks ❤️ 0 8855 a building inspector should be able to tell you about any major problems but we need a floor plan with dimensions to clarify options for extra bedrooms ... sometime an… 1 8715 |
