Browse Forums Renovation + Home Improvement 1 Mar 01, 2018 10:31 am My neighbour has a rotten door jam, at least the side near her bath tub is rotted(where the hinges go). I will post a picture later, but i'm wondering, can I just replace the side that has dry rot or do I need to replace the whole lot? I will post a pic soon. Is there anything special about the installation process? I have a multi tool, drill, and other tools. Thank you Alexander Screed is installed before or after, what was not up to code? You have 4x images, door frame, The work is poorly applied rough, with no care for how it should be done, if… 5 2651 Just be careful with building stability during construction, that is when the structure may be weakened, refer to your engineering drawings for stability methodology. 1 7224 Can anyone recommend a good/affordable retaining wall and fence builder that I can get a quote from located in Sydney? 8 45801 |
