Browse Forums Renovation + Home Improvement 1 Feb 24, 2018 4:33 pm Hi all, I live in Essendon, Victoria and am wanting to renovate however I'm just not too sure of what my first step should be. Essentially we're wanting to extend a section of the house (about 8m long) out to the boundary. I'm not too sure if we should first go to an architect to have what we want drawn up - and then head to council, or go to council first? I say this as I'm under the impression that extending out to the boundary can result in array of red tape or maybe juts a hard no from the council. Any guidance or considerations would be greatly appreciated. Thank you, Re: Very first step - Architect vs Council 2Feb 25, 2018 9:57 am Hi DanRaw Welcome to the forum I do recommend you check with the council first this is why 1. Architects/Designers charge heaps by the hour , so get a fixed price (should be <2K total for 2D, 3D,Elevations, Data, Quants) 2. Council employed planners should assist you with the residential design codes and any quirky amendments they may require 3. The planners also have checklists on building approvals which follows planning, etc Trying to source all that information online can be overwhelming i suggest you go into the counter and ask OT, During the perth boom they would fob you off to expensive external Planning consultants, now because it's slowed down they are falling over to help people/rate payers, this is because some are now being laid off Are you doing an owner builder if so you will need Quantities, Rate$ , Approx. Costs etc.. BTW photos also help Goodluck Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Very first step - Architect vs Council 3Feb 25, 2018 1:59 pm Hi StructuralBIMGuy, Thank you so much for the advice - greatly appreciated. I'II head off to council first and take it from there, I'm sure they'll get bit of laugh as I describe items as thingy's and whatit's Great tip re: getting a fixed price for the architect drawings too, thank you. As most people do we've walked through our house pointing at walls with the standard .... "Lets just move that by 2m" .... beyond speaking with the council and inturn architect, it'll be interesting to see how much it'll cost to get want we want done. Thanks again, Dan Re: Very first step - Architect vs Council 4Feb 26, 2018 9:59 am I am in a different council to you (Glen Eira), but much to my surprise I found them to be very helpful when I initially phoned up with a general query like yours. I just phoned up and asked to speak to someone in the building/planning dept and the guy I spoke to was able to provide a lot of background and general info on what I could and couldn't do. There is some light reading here as well http://www.legislation.vic.gov.au/Domin ... -068sr.pdf Re: Very first step - Architect vs Council 5Feb 28, 2018 9:31 am Danraw Continuing on from planning is Costing & Building you might want to also read Knockdown & Rebuild Upgrade costs & Site setout on home extension Having the right BIM Tools (Building Information Model, Construction & Engineering, data,quants,etc) will also assist you greatly. OT Bear in mind Architects do not do BIM Engineering , which incidentally is critical onsite during the build Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11835 Do I need to concern about this pattern of crack? Is this crack showing some signs of bigger problems? Thanks for any suggestions! 1 1914 Take a pick with a level sittingo n the slab and a pick with a level sitting on the sill please. This will help us diagnose the issue and therefore a solution. RE,… 8 9393 |
