Browse Forums Renovation + Home Improvement 1 Jan 26, 2018 4:44 pm Re: Converting bedroom to bathroom- need ideas on floor plan 2Jan 28, 2018 8:43 am That will work well. Is the floor structure bears and joists? If so as long as there is good access under the floor getting the new plumbing in should be doable. If the floor is a concrete slab it will start to add a lot of extra cost to the project. Do you have a budget to work to, or just getting ideas? start from at least $20,000 just for fixtures and finishes and then add on for moving plumbing and extra for a concrete floored house last new bathroom we installed in a… 1 19591 This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 11258 6 55354 |
