Browse Forums Renovation + Home Improvement Re: Cladding suggestions 2Nov 10, 2017 9:35 pm HI, We are looking at renovating the exterior of our home. We are considering weatherboard a bit of painted brick (all in same colour), but also considering a mix of weatherboard and vertical cladding (like Scyon axon). We would like to keep the roof as tile and just have it painted. The problem we have is that there are no safeet on the side of the house, which means we can't do weatherboard/cladding that require a stud because they'll protrude out further than the roof. Do you think we should just paint the brick on the side? Or does anyone have any other suggestions? Thanks! Re: Cladding suggestions 4Nov 15, 2017 9:47 am hi, i replied to u on the other site. but didnt see these pics. thats a lot of area and rendering is out of the question. this muat be a perth house yes? Re: Cladding suggestions 5Nov 15, 2017 10:59 am rebuilder86 hi, i replied to u on the other site. but didnt see these pics. thats a lot of area and rendering is out of the question. this muat be a perth house yes? Hi, actually Gold Coast! We are starting to consider the option of just painting brick and maybe just having some timber batten feature areas... Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12052 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11118 Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 5646 |
