Building ForumRenovation + Home Improvement
VJ walls cracking within days of painting
Hello,
We recently had our Queenslander with VJ walls painted by a professional painter. Within 3 days the vertical joints had began to crack. There are now a lot of cracks in most rooms, affecting both the walls and ceiling. I did see the painter use no more gaps/a similar product. Is it common for cracks to appear this quickly?
I had never appreciated this degree of cracking with the previous paint which must have been almost a decade old. The painter put it down to "house movement" and temperature changes. Does this make sense with such rapid crack formation? Is there any other reason for cracking to occur so quickly?
Thanks!
1
Cracking Hebel root cause analysis
General Discussion
How wide are cracks? Can post some photos
16/01/2024
Mondays are your days
Interior Decorating Lounge
I'll be here once a week, lets make that Mondays. > If you have a question, this will be the day I will log in for a look around.. If your lucky, sooner. Ask away...…
