Browse Forums Renovation + Home Improvement 1 Sep 08, 2017 3:46 pm Hi everyone In case there were a similar situation you knew or saw, The rumpus was garage before converted in 70s, conrete slab, brick veneer wall. Noted a back corner sinking several years ago when moved in, and a big tree was removed around that time with stumps grindered. That corner side seems sinking each year and now the front corner in the same side now have 1 cm gap. Recently tried to get into craw space and noted some water sitting same side, where then identified a downsprout blocked by leaves below ground. The position is about 2 to 3 meters to the sunken corner as mentioned above. Got a plumber to clean out the storm drains and replaced broken part near front and most likely by tree root. It all happens in the same side! I am thinking what would be reasonable or good to level indoor slab, and Who to engage i.e. a civil engineer first, and timing , let moisture gone say after summer to repair? Any experience or recommendation ? Thanks It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17202 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17527 |
