Browse Forums Renovation + Home Improvement 1 Jul 16, 2017 11:33 pm Hi It is my first time posting here so sorry if i am doing anything wrong. In a bathroom renovation with a timber floor and subfloor, my question is that is it ok to put cement sheeting 6 mm directly on floorboard. And then water proof and screed and tile? Is there anything required for the shower area? Is it ok to use gyprock aquacheck for the walls in shower area? I appreciate your assistance in answering my question. Cheers Re: Renovating bathroom 2Jul 17, 2017 8:31 am Hi mate, the 6mm sheet can be used, although I would advise against it as a more durable 16mm compressed sheet would normally replace the timber floor below. With the 6mm if it's not installed properly there is to much risk of movement with the floor boards below that can cause problems with your tiled floors in the future. With the walls aquacheck can be used, although 6mm villaboard on all walls is again a better finish for walls with full height tiles. Good luck with it all. Regards James Mason www.renovationjunkies.com.au Re: Renovating bathroom 3Aug 09, 2017 10:32 pm It would be better if you used 16mm compressed sheet instead of 8 mm compressed sheet . By using it , it became highly durable & stay for long time. What you are looking at is fibrous plaster, true gypsum, it is cast on horizontal beds with fibers included to give strength. I has no Asbestos in it. Houses before 1985… 2 7113 Render your bathroom walls, two opinions versus the one, makes you wonder. 3 6035 Hi Geoff Install Puddle Flange prior to any screed. Puddle flange needs to be flush with the surface so you may need to grind away the surface to achieve this. Also as… 2 8323 |
