Browse Forums Renovation + Home Improvement 1 Jul 10, 2017 10:25 pm Hi all, Helping my brother with his bathroom, he is starting from scratch as he is remodeling the entire bathroom so the tiles old villaboard walls etc have all come down. I had a few people mention to me a different order in which the tiling should be done (not professionals) It's been a while since I did my own and just want check the way it's meant to be done and the order. Out of the list below, what order would you advise or know it to be done? I'll put it in the order I was going to do and appreciate being told different or the correct way 1. Villaboard the walls 2. Waterproof the walls and the floor 3. Tile the walls from floor to ceiling (except bottom row) 4. Waterproof the floor and into the corners of the walls where meets the floor 5. Put down the bedding of sand and cement and float run off to the floor drain 6. Tile floor 7. Go around and cut in bottom row tiles I'm 50/50 in thinking I should probably screed the floor first so that is waterproofed under the tiles itself rather than waterproofed under the screed where the floor is uneven etc Thanks heaps Geoff Re: Which order for tiling a bathroom 2Jul 14, 2017 1:11 pm Rightly or wrongly the order that I tiled my bathrooms was as listed below: I did the floor last to prevent it from being damaged when tiling the walls. I also left waterproofing the floor to as late as possible to minimise possible damage to its waterproofing. 1. Villaboard the walls including putting flashings in corners behind the walls and between floor and wall. 2. Flush & Paint ceiling 3. Put down the bedding of sand and cement and float run off to the floor drains 4. Waterproof the walls 5. Tiled the walls from floor to 2.2m (except bottom row) 6. Waterproof the floor and into the corners of the walls where meets the floor 7. Tile floor 8. Go around and cut in bottom row tiles 9 Grout, etc 10. install fixtures etc 11. Silicone around fixtures I am new to this forum so please bear with me. An NCAT order was breach by our neighbour regarding a retaining wall dispute. He is the owner of a building company and he… 0 2209 Looking to tile the facade pillars rather than rendering. Builder is quoting 2500$ laying cost for upto 10msq. The 2 pillars come to be 16msq. So laying costs are 5000$… 0 7550 Hi, I'm clearing the tiles from our horrid 50 year old bathroom and preparing to lay new ones. Bugger of a job getting the old… 0 8088 |
