Browse Forums Renovation + Home Improvement Re: Floorboards 3Jul 18, 2017 10:22 am Hi there, not sure if this decision has been made - I am in the midst of renovating and yes, I could have gone laminate, however I like the look and the feel of of a solid floor (it has not been without its hassles mind you). Let us know what you went with Confused Renovator Re: Floorboards 4Jul 18, 2017 11:41 am DamNita it has not been without its hassles mind We decided on re-milled timber in our new build. In the interest of wanting to avoid any pitfalls, would you care to explain what hassles you have had in a hope that we might avoid similar. Re: Floorboards 5Jul 18, 2017 1:00 pm We bought second hand floor boards (jarrah) then laid them out selves on a little 20mm joist system so we get some bounce and give and then got someone into sand and seal Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ <!-- l --><a class="postlink-local" href="https://forum.homeone.com.au/viewtopic.php?t=62083">viewtopic.php?t=62083</a><!-- l --> Re: Floorboards 6Aug 12, 2017 10:05 pm If you want durable, high quality ,stain free or solid flooring than you can go with a solid timber floor. Easily maintained and cared for, solid timber floors create opulence in any home. Can be sanded and re-sealed if damaged or scratched as well Re: Floorboards 7Sep 11, 2017 12:02 pm arcadelt DamNita it has not been without its hassles mind We decided on re-milled timber in our new build. In the interest of wanting to avoid any pitfalls, would you care to explain what hassles you have had in a hope that we might avoid similar. ...apologies for the late response. My main issues have been the quality of the timber we got. We are in NSW and I chose QLD Spotted Gum, Select grade, Satin Finish. From the onset my floor layer told me it was NOT select grade. I went back to the supplier, he assured me it was and would not be in a position to exchange or replace my floor. The floor layer thought that I was not forceful enough (could have got an inspector for $500) but my supplier was an 'honorary member' of the association. I knew we just had to power through it. Suffice to say, I love the floor now that we are in. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Confused Renovator Re: Floorboards 9Oct 29, 2017 12:12 pm There's an article in reader's digest home maintenance (I have the book, only good thing my ex ever gave me) on how to fill holes and chips in floors which is super cheap and looks pretty easy to do. You make a pulp in a bucket of news paper and wall paper glue (if I were doing it I'd try to stain it at this stage) then fill and sand, then finish as normal. Hi All New to the forum and looking for some advice, has anyone else renovated an old miners cottage in or around Ballarat and been able to identify the flooring? We… 0 8771 Hi there, looking to have a gym in a new build. Planning to install some sort of rubber mat flooring (on concrete) i.e. Asking the builder to not do floorboards in the gym… 0 1009 |
