Browse Forums Renovation + Home Improvement 1 Apr 04, 2017 9:42 am Hi during the summer months our living areas with raked ceilings are extremely uncomfortable. We have raked ceilings and are considering using insulation between the rafters/beams. Then plastering over the top so the beams are no longer visable. Can anyone advise if this is a reasonable solution and any advice for achieving the best result. Thanks in advance. P.S not sure how to attached a photo to give better explanation. Re: Insulating Raked Ceiling 3Apr 14, 2017 11:32 pm Probably you mean joist the space between them is 40 or 60 batts can be bought either siizes I have recently installed R6 gold batts so if you have roof space then go for them. easy installation just use strings to attache them to the existing roof then plaster the ceiling. How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5947 There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water… 0 2453 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17202 |
