Browse Forums Renovation + Home Improvement 1 Mar 10, 2017 4:28 pm Hi, I am looking to knock out a small wall (~1.5m long) to open up a space for a new kitchen and want some opinions on whether it is load bearing? The ceiling is pitched (parallel to tin roof) with approximately a 300mm cavity. I have tried to crawl under the house to determine if there is any obvious reinforcement under the wall to no avail (very little crawl space). The bearers appear to be running perpendicular to the wall. Photos below: https://ibb.co/cJ9eRF https://ibb.co/gKt66F https://ibb.co/mEdHDv https://ibb.co/kr5a0a https://ibb.co/ctXG6F Thanks in advance, James Re: Structural Wall? 2Mar 10, 2017 6:40 pm Hey mate Thanks for the pictures, it's a little hard to tell unfortunately. That short wall may take a beam that divides the span of the room. Best bet would be to remove a few roof sheets above and look over the top of the wall. This way you can get a better visual of the area. If it was carrying a beam you could always look at creating a large opening in the wall above the kitchen bench height. Let us know how you get on. Kind Regards James Mason - Our Build. www.renovationjunkies.com.au www.ourbuildhandyman.com.au Assuming you've modelled the TB8, TB10, TB12, TB2 & J1 joists/LVLs there, it appears as per drawing to me. There maybe should be an additional J1 between TB10 and T12 if… 3 31928 interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing… 13 47047 |
