Browse Forums Renovation + Home Improvement 1 Feb 25, 2017 1:49 pm Hey, So i have some left over tile underlay from the floor and have run out of villaboard. My question is what is the difference between villaboard and tile underlay? Why cant i sheet the walls with tile underlay? They are both fibre cement.... Thank you for your answers Re: Villaboard vs tile underlay 2Feb 28, 2017 1:32 pm Villaboard is impact & water resistant. Drill it and you'll find out. Tile underlay is not water resistant, you cannot use it to sheet a wall in a wet area, but you could otherwise if you are happy with the texture. If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8303 Hi All, First time poster. I was hoping to get some advice on villaboard installation within a bathroom. I have installed villaboard before, in a laundry. I think I did… 0 7455 Hi l plan to install a self adhesive vinyl plank floor. l first need to attach masonite boards underlay to by plywood subfloor of my house. What size nails and how many… 0 8364 |
