Flat roof -
First time posting...
I am contemplating a 90 sqm extension and looking at whether a flat roof is feasible. My questions are:
- what are the build options apart from a poured concrete slab (could we do a skillion hidden by a parapet - there span is pretty wide? why would you go for one or the other? if we went away from a rectangle design does that mean we have to go concrete slab
- if we go the concrete slab, is that a lot more expensive, relative to a gable roof say or hidden skillion? I am in inner Sydney
Any help/pointers to info would be appreciated,
Thanks!
Colourbond can do 5% fall in some profiles. SIPS can do the same. Hebel could possibly do less with a waterproofing membrane (expensive).
hidden skillion usually means box gutter, which at some point in the future WILL leak into the house. Something to bear in mind...
On-site poured concrete roof would be many times the cost of a traditional skillion or gable roof.
1
I would suggest you simply go and talk to council about your proposal, most councils are getting onboard with ancillary dwellings. There is no benefit in keeping it…
31/12/2023
I think I know the answer but just checking to see if anyone has had experience with it. I want to build a small 20 square metre retreat in my backyard, it will have a…
24/01/2024
Any advice on how to ensure the kit home granny flat that im thinking of buying will get council approval. The kit home companys wont release plans without a deposit and…
