Browse Forums Renovation + Home Improvement 1 Feb 09, 2017 1:46 pm hi all
i am currently looking at purchasing a house at Auction this weekend and need some opinions on doing a small extension in blueboard.. the rest of the house is blueboard rendered and in good condition at the back of the house there is a small like sunroom (approx 4x5) and attached to is a small deck (3x3) and a laundy (2x3) which uses the width of the house at the back my plan is to knock that down and extended a metre longer so might turn into something like 5 x 12 does any1 have any rough costs on what that would cost to do it properly in blueboard with proper roofing too? id want to install ducted aircon after and would want vents in that part of the house so assume you would need to be able to get into ceiling? I have ideas as per below... thoughts? 2 stages of floorplans depending on what we can afford which ofcourse depends on what the house sells for. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: SMALL EXTENSION TO BLUEBOARD HOUSE 2Feb 09, 2017 2:08 pm A little hard to tell without seeing photos of the area and all the details, but you wouldn't get much change out of 150K in my opinion. Kind Regards James Mason - Our Build. www.renovationjunkies.com.au www.ourbuildhandyman.com.au Re: SMALL EXTENSION TO BLUEBOARD HOUSE 3Feb 09, 2017 2:10 pm Our Build123 A little hard to tell without seeing photos of the area and all the details, but you wouldn't get much change out of 150K in my opinion. Kind Regards James Mason - Our Build. http://www.renovationjunkies.com.au http://www.ourbuildhandyman.com.au i can give more details... what do you want to know... there is a sloping roof over the back part of sunroom please see floorplans attached Hey, I am wanting to add a second toilet to my house, bit we have limited room. There is a hallway/entry that is never used, so was thinking this could be an option. Only… 0 4672 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8373 Hi all, We are looking to build a new two storey house in western Sydney. Can anyone recommend a smallish builder to go with? We are trying to stay away from the big… 0 12042 |
