Browse Forums Renovation + Home Improvement 1 Jan 10, 2017 3:08 pm wanting to fit some hinged doors in place of sliders wasnt sure where to position the hinges so went to google now i am more confused i have found 150mm,175mm, 200mm, 250mm, 280mm, 285mm, 300mm some use the same for bottom hinge some use a different number is there a standard Re: hanging doors 2Jan 10, 2017 3:33 pm aussieta wanting to fit some hinged doors in place of sliders wasnt sure where to position the hinges so went to google now i am more confused i have found 150mm,175mm, 200mm, 250mm, 280mm, 285mm, 300mm some use the same for bottom hinge some use a different number is there a standard If they are standard internal doors go 150mm down from the top and 150mm up from the bottom. I made a How to vid last year, see if this helps - https://youtu.be/OV9EC-RR6Ac Good luck! Kind Regards James Mason - Our Build. www.renovationjunkies.com.au www.ourbuildhandyman.com.au Hi Stuey, think you’ve got a couple of options here you’d just need to decide your preference/which options suits best. You could recess the windows (just keep in… 1 3993 we have a standard size and often we have a lot of variety to choose 0 3575 We are looking for sliding doors which are 5 metres tall. There are a few European options. Any manufacturers in Australia or distributors? 0 5039 |
