Browse Forums Renovation + Home Improvement 1 Dec 12, 2016 8:26 am How do i best protect a ceiling built underneath a deck? Does anyone have some photos to share? The difficult thing is I was hoping to fully clad up the side up to the deck, making the roof onto of the ceiling a little more tricky. Any ideas? I could screw iron up to the joists, running inwards, gutter, and put into a close-by waste pipe, not much risk to my plaster ceiling as there should be very little water getting in anyway. Is that the best way, then it is fully enclosed? Re: Building in underneath a deck 2Dec 12, 2016 6:08 pm Fall will be going towards the left, where the slats are, that will be cladding. https://1drv.ms/i/s!AuneGdR1T9lQg4NyOvEMqgcifB7HWw Re: Building in underneath a deck 3Jan 23, 2017 3:43 pm you want to enclose the underside of the deck, both walls & ceiling? If the deck roofed/walled above the deck level? That style of deck is by design not sealed- you cant put a plaster ceiling under it & expect it to last. The most likely cause of your timber swelling (parquetry?) is either a plumbing leak or carelessly leaving water on floors after use or both. Without seeing, i am ignoring… 1 3283 Currently renovating, and our main lounge is 5m x 10m, with a cathedral roof peaking at 6.5m high. Currently have tiles on concrete slab. Room is very hard to heat. I am… 0 4822 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20237 |
