Browse Forums Renovation + Home Improvement 1 Nov 24, 2016 1:34 pm First time kitchen builder, I've just installed all the base cabinets in the kitchen and just wondering if I should continue installing all the cabinet doors and drawers before getting the stonemason in to do his thing, or should I get the bench top installed first and then do the doors and drawers last? Thanks. Re: Quick Kitchen Installation Question 2Nov 25, 2016 6:01 am Personally I'd put them all on, you can make adjustments in the hinges later if needed, but if installed correctly you won't have a problem. Kind Regards James Mason www.renovationjunkies.com.au Re: Quick Kitchen Installation Question 3Nov 25, 2016 8:00 pm Nearly all hinge manufacturers have clip on hinges. I'd install all the doors and drawer fronts ( if you are waiting on the stonemason that is ) and the day before he is due to lay the benchtops remove them all and stack them on their edge in another room. If they are cutting the sink onsite there will be a lot of dust and possible damage to the doors. It also makes it a lot easier for them. I'd prefer to be safe than sorry if it were me. Stewie Re: Quick Kitchen Installation Question 4Nov 28, 2016 8:23 am Stewie D Nearly all hinge manufacturers have clip on hinges. I'd install all the doors and drawer fronts ( if you are waiting on the stonemason that is ) and the day before he is due to lay the benchtops remove them all and stack them on their edge in another room. If they are cutting the sink onsite there will be a lot of dust and possible damage to the doors. It also makes it a lot easier for them. I'd prefer to be safe than sorry if it were me. That's very logical - I think I'll go with this. On another note, the stonemason mentioned there might be a 5mm gap between the benchtop and the IKEA cabinets due to the metal support brackets and risers. Does that sound about right? What would be the largest acceptable gap between the benchtop and cabinet be before it started to look ridiculous? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 1. Roof cleaning and paint - which colour do you recommend? I often see black/ dark grey in use these days but I would prefer… 0 8333 I need to replace the worn mohair seal on my sliding window, but I can't get access to the end to slide the old one out & push the new one in. I could probably rip the old… 0 5202 Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6165 |
