Browse Forums Renovation + Home Improvement 1 Nov 13, 2016 8:46 pm I want some walls removed to open up kitchen and living area in a 1980s house, i may not want to completely remove load bearing walls, may be just to open part of it. My question is i am not sure whom to engage first to assess what and how can be removed so that i wont harm the structure, Re: Remove walls 2Nov 15, 2016 7:23 pm Hi Daredevil. Are the walls masonry or timber framed? Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Remove walls 4Nov 19, 2016 7:56 am Most builders or carpenters could point you in the right direction. Here are a few videos to show you a couple of options for both brick and timber load bearing walls. Timber - https://youtu.be/jFkFfRIUapQ Brick - https://youtu.be/_DlwtgzXVQw Hope it helps demonstrate what the construction process looks like. Good luck with it! Kind Regards James Mason www.renovationjunkies.com.au Re: Remove walls 6Nov 25, 2016 5:38 am Sure, try a site called HI Pages, you will get three quotes from licenced contractors - www.*.com.au Kind Regards James Mason www.renovationjunkies.com.au How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5933 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11835 You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of… 1 7071 |
