Browse Forums Renovation + Home Improvement 1 Oct 08, 2016 8:34 pm Hi All, Just after some advice regarding painting, fixing and filling nail/screw hole s in our future MDF skirting after our floating floor are installed after handover. The house we are currently building used steel frame so what is the best way to fix the skirting to the steel frame? Some sort of nails or should we go with some sort of glue? In relation to painting, should we paint the first coat while the skirting is uncut? Than do the next two coat after its installed and the nail/screw holes are filled. Also what should I use to fill the holes? Our McDonald Jones Cordova Two Build - http://cordovatwomjh.blogspot.com.au Re: MDF Skirting Painting and filling nail hole 2Oct 09, 2016 7:47 pm Best way to fix, depends if you can hit the stud and track, personally I would just use liquid nails and if you have access to a nailgun use 50 mm fixout nails and shoot the nails into the gyprock in a V pattern every 500-600 or you can locate studs and screw but will require more time being filled by the painter I think it would look really crap as a finished product, you can paint if you want up to you yiu might see nails holes easier if you do 1 coat xD Re: Build with G. J. Gardner 3Oct 10, 2016 12:11 am Thanks mate. Love the sound of Liquid Nail as it's sounds like a nice clean easy solution. Do you reckon over time it may peel or lose its adhesiveness? If I go Liquid nail route should I just paint all 3 coats prior to the cutting and fixing of the skirting? LochietheChippy Best way to fix, depends if you can hit the stud and track, personally I would just use liquid nails and if you have access to a nailgun use 50 mm fixout nails and shoot the nails into the gyprock in a V pattern every 500-600 or you can locate studs and screw but will require more time being filled by the painter I think it would look really crap as a finished product, you can paint if you want up to you yiu might see nails holes easier if you do 1 coat xD Our McDonald Jones Cordova Two Build - http://cordovatwomjh.blogspot.com.au ask the surveyor for clarification would be the logical approach 1 20144 Probably a not bad thing to mention particle board should in case anyone else reading this got the two confused. 6 4906 DIY, Home Maintenance & Repair Hi there, I just recently received my new house from my builder. We handed the house to another company to deal with the… 0 8914 |
